Jim
Jun 19, 2016Explorer
I usually clean as best I can, turn off the water, than pour a little ATF in the empty bowl. Let it sit in there a couple days. It will often cause the seals to expand a bit which will cause it to seal against water again. Usually only had to do it once a year after the rig had been sitting unused for a bit.
38,769 PostsLatest Activity: Mar 31, 2026
