Ls.telly.icloud.com wrote:
GENECOP wrote:
You can flush with the light on, hold the button for 10 seconds it will flush.. Reconnect the high limit sensor......FLUSH THE Tank 3-4 times....fill to top, stay Inside listening to sound as water rises, dump and fill again......the sensor needs to be cleaned....it happens with these toilets....
Where us thr “high limit” sensor located and can I manually clean it without having to flush 3-4 times. I am dry camping now and don’t want to waste all that water??
The Toilet level sensor is NOT inside the tank. It is glued on the outside wall of the tank NO cleaning necessary. Doug
