Mr_Mark1
Jan 04, 2016Explorer
Shaftslinger wrote:
Thanks for the replies
For the people saying look elsewhere could you recommend a unit?
I'm just not seeing other deals currently but I'm new to this. So I may be looking in wrong place
First, I'm not surprised at all that TS was not acceptable. You could tell just from the pictures that there probably was going to be a LOT more going on. When you said 'wiring cut-up'.... that would be major to repair correctly.
Anyway, I'm not sure if anyone mentioned a good site to check out used units, so here is one.....
www.pplmotorhomes.com
They are located in Houston and have several locations. If you see something that you like and it checks out, make your lowball offer and see what happens. You never know.
Good luck.
MM.
On Edit: I looked at PPL and unit number D725 is a '99 Monaco Signature, 42 ft. w/one slide-out. It looks in decent shape except the rear monitor has been removed from the dash. It has been mentioned many times to go with a high end unit for the best value and quality. You never know, maybe upper $30's might buy it (asking $46,495). Lots of motorhomes to view PPL.
