dougrainer
Jan 03, 2018Nomad
Your system uses Hydraulic power to extend and raise AND keep retracted. If the shop thought the individual jack assbly's was a possible fault, no wonder they cannot fix it. They have no clue how the system operates or to fix it. So, they throw parts at it. Both LCI and Kwikkee have excellent phone support and on line service manuals. In your case, IF a jack starts to extend in transit, the most probable cause is a internal leak at the solenoid at the pump for that jack. If you have more than 2 jacks extending in transit, the odds are the full retract solenoid is leaking internally and that lack of pressure causes the jacks to start to extend. Good news is, they will extend until the pressure equalizes. They will NOT continue to the ground. FIND ANOTHER SHOP THAT KNOWS WHAT THEY ARE DOING. Doug
38,769 PostsLatest Activity: Jun 25, 2013
