D_R_Bain
Jan 04, 2018Explorer
maddog348 wrote:
2007 Itasca Sunova 27'. LEVELERS BAH!!!! AM tired of messing with a failed Hyd sys. Kwikee System taken over by Lippert. On vacation last Spring RT Rear leveler began decending on its own while traveling on the Highway. Lights & Bells ~ Stop!!! hit raise jacks all went back up ~ for about 70 miles. Limped along for a while to primary Vacation spot. AS was under extended warranty wanted our regular repair shop to checkit out. BIG bungees ~ check leveler every 50 mi ~ Home OK. THAT was in June. Shop had to check with mfg. then ins. no longer made had to build. Ok 6 wks Did not cure. Mfg said try this ~ Then that 2 more jacks to build & replace ~~ OOps that did not work. Mfg must be 2 way valve ~ Approved day before extended warranty went out. Shop finally found proper valve ~ OUR $$$ ~but must by 4 of them. Closed for Holidays ~~ Shop called today Levelers are "frozen". Will go thru system again maybe one of new levelers no good.
Note!! other than that may be the HYD Pump -our $$$ --. I am worn out with it~~ Any one just remove levelers & go back to blocks.?? Old Classs C saw a lot of camping with Boards&Blocks. Am afraid to drive it with the levelers decending unannounced.
Thanks for letting me vent.
I have found that when my levelers do this I found low fluid level in the reservoir. As long as I top it off once a year it keeps everything from triggering the alarm bells and whistles.
38,769 PostsLatest Activity: Jun 25, 2013
