enblethen
Feb 09, 2014Nomad
Diagram that I looked at shows it about in the center of the under dash fuse block. Diagram says it is marked "VEH CHMSL" should be 10 amp.
It appears to be right above the 12 pin Body control module that it says is brown.
Not sure if this link will work.
Fuse block
Fuse block
38,773 PostsLatest Activity: Apr 25, 2026
