Gjac
Oct 12, 2020Explorer III
Thor Axis 24.1
I wasn't sure if this belongs here or in the Class C section. But while looking for short Class C's (24 ft) I noticed a new Axis 24.1 which is only 7 ins longer than the C's I was looking at. It also ...
JRscooby wrote:way2roll wrote:JRscooby wrote:A1ARealtorRick wrote:
"......but also have a lower tow rating (18,500 combined vs 22,000 combined)"
But unless you have a Sherman tank as a toad, for most the difference in tow rating is probably a non-issue :C
I'm not going to look up the weights, or GVWR of the vehicles but at most I bet the ratings allow for a bump of tow ratings of going from 6000 to 10000 lbs. Hardly "Sherman Tank" range.
Well thanks for that clarification! There goes me wanting to bring my tank along. Just got it set up to flat tow too...A1ARealtorRick wrote:JRscooby wrote:A1ARealtorRick wrote:
So what kind of toad DO you plan to tow in the "6000-10,000 pound" range? That's still pretty heavy.
My point is that a 3500 lb change in GCVWR means less than the same change in GVWR. And any time a rating increases some of it is used up in extra weight of the vehicle,
