Gjac
Oct 12, 2020Explorer III
Thor Axis 24.1
I wasn't sure if this belongs here or in the Class C section. But while looking for short Class C's (24 ft) I noticed a new Axis 24.1 which is only 7 ins longer than the C's I was looking at. It also ...
way2roll wrote:You are right my current 33 ft Class A can't tow that much. When I compare specs against other Class A's or space against small Class C's. HP/wt ratio, WB/L ratio all look impressive. The only concern is the quality of Thor products. That is why I asked if any on here actually own one, but not one owner has responded yet.A1ARealtorRick wrote:
"......but also have a lower tow rating (18,500 combined vs 22,000 combined)"
But unless you have a Sherman tank as a toad, for most the difference in tow rating is probably a non-issue :C
I was surprised at the 2020 specs for capacity on such a small coach. Depending on the model there is between 6-7.5k lbs of actual towing capacity. Impressive for such a small coach - or maybe it's because it's a small coach. There are a LOT of larger gassers with almost no capacity left.
