knowing Thor, if they spec Jensen components, the rear TV will have a 12V TV with integrated DVD. It will either be top or side load. The main TV likely will not be integrated but any new TV will have a host of input ports including HDMI. Be as simple as buying a $20 DVD player and some RCA jacks and plug it in. Oddly any particular unit can come with different components depending on what they have in stock when they build it. 2 Side by side units may have very different brands and TV configurations. Any of this can be changed easily often swapped at the dealer no charge. Further, add a switch box and you can centrally install a dvd player and use the switch box to run it through any/all your TV's on/in the coach.
