Sloop_Smitten
Sep 16, 2014Explorer
What does the sticker say on the driver side door beam?
What rating tire are you using? (C, D, E?)
What is the maximum pressure listed on the tire?
Are you using the same tire rating as is listed on the sticker?
I don't like to run over 25% less than than the maximum rating on the side of the tire. I have similar "E" rated tires and similar weight as you. I run 60 in the front and 65 in the rear and the ride is not too harsh or soft. Tires are rated max at 80. The sticker on the door frame is for "D" rated tires and it recommends 50 front and 55 rear. If you have the same rated tire as the sticker calls for I would use what is listed on the sticker.
38,769 PostsLatest Activity: Mar 31, 2026
