j-d
Sep 17, 2014Explorer II
Got a slide on the Driver Side? Did you have People aboard as well as your travel load?
If you want, I can pull up a chart and do the lookups, but basically this is why the Michelin chart is by "corner" and not just "axle."
Recommended pressure, given you weighed it loaded (cargo and crew), would be whatever the Single part of the Chart specs for 2060 for BOTH fronts. And for BOTH rears, whatever the Chart shows for 3580 Dual.
Rear pressure a little higher than charted numbers won't affect much, but try to keep front as close to what the chart says. Any excess front pressure affects tracking.
38,769 PostsLatest Activity: Mar 31, 2026
