DFord
Mar 07, 2020Explorer
I have no idea what kind of mixing valve you have on your shower but I'd suspect some debris in the line leading to the how water side. The easiest way I know of to make sure would be to drain the pressure on your system and remove the valve for inspection. Once the valve is removed, you could put a plug in the cold water line and a hose on the hot water side and pressurize the system and see what kind of flow is available to the shower. If you get a full stream with plenty of pressure, the problem is in the mixing valve and it would need to be backflushed, disassembled for inspection or replaced.
38,773 PostsLatest Activity: Apr 23, 2026
