ericsmith32
Dec 24, 2015Explorer
IAMICHABOD wrote:
You should have no problem at that mileage,I have a 2006 Former Rental on a Chevy Chassis and if it was maintained well it will go a long ways without any problem.
I just had the 100,000 mile service completed and the only thing it had was a small leak on the transmission tail shaft that was fixed,I would also check the rubber brake lines,one was soft so I had all of mine replaced.
Other than that it has been trouble free,just regular maintenance as you would do on any other vehicle. These newer vehicles are produced to have longer lifetimes,hence the long warranties that are on them from the factory.
If you don't mind how much did that cost you to fix? Ours is leaking bad out of the back, also out of the front but not as bad. Common issue it seems with the 4L80E.
38,782 PostsLatest Activity: Sep 10, 2026
