IAMICHABOD
Dec 24, 2015Explorer III
ericsmith32 wrote:IAMICHABOD wrote:
I just had the 100,000 mile service completed and the only thing it had was a small leak on the transmission tail shaft that was fixed,I would also check the rubber brake lines,one was soft so I had all of mine replaced.
If you don't mind how much did that cost you to fix? Ours is leaking bad out of the back, also out of the front but not as bad. Common issue it seems with the 4L80E.
The part was $38 and the labor was $220,your cost may be different but out here the labor cost is $140 per hour for RVs.:E
My mechanic gives a 2 Year warranty on all his work.
38,782 PostsLatest Activity: Sep 10, 2026
