michbill wrote:
Thank you all for the great responses' You guys are great!!
Mark, thanks for the specifics!
Ivylog, For the black and gray tanks I have the "honey truck" come and pump us out. Can you tell me where the " Dynasty's heater" switch might be. I have never heard of it. I have Aqua-Hot system.
Has anyone set up a security system in/for the coach? The area is not a "big" problem but we have to be at the nursing home for a lot of hours a day and I would feel more comfortable with some kind of system.
Thanks
Bill
Most of the Monaco products with an Aqua Hot that I know have a heater outlet in the bays where the tanks are. It is usually set about 40-45 degrees. If you leave the AH on it will heat your bays if everything is working correctly.
