sssooo's avatar
sssooo
Tiffin rant
1 unit this is list of stuff I would think was above a Tiffin,this is my 4th motorhome I kind of been around the block2
2 the window on the pass. seat leaks ,just a little bit only when it rains
3 the jacks sage on driver side every 2or3 days had to raise them
4 I have a squeeky floor in the bedroom I quess that Tiffim for you
5 the swower door is hard to close it hits on the bottom real hard
6 the shower leaks bad [I quess I can caulk it!]
7 I HAVE 3TV's ALL PANISONIC SAME REMOTES YOU CHANGE CHANNELS ON 1 IT DOES IT TO ALL OF THEM YOU CANT USE HEAD PHONES SO YOU CANT HEAR YOUR OWN TV ON A DIFFERENT CHANNEL?? I DIDNT GO TO COLLEGE BUT I FIGURED IT OUT THIS IS A BAD SETUP!!
8 the storage compartment over the drivers seat is about 5 inches to shallow,my satellite reciever stickes out about 4or5 inches it fell down on me going down the road [not a pretty site] it needs to be deeper! come Tiffin I thought you were better than that
9 I have single pain windows and the latches are real hard to open
10 the switches for the water pump are a stupid setup they need to have the lighted type of switch so you can tell if it is on or not
come Tiffin I thought you were better than this
Now I know this is a used unit but still I was expecting better than this
