- Just_JeffExplorerMy Greyhawk has a lot of wiring under the bed, too...it's mounted to bare plywood under there. There's just enough carpet so that you can't see any bare wood until you remove the cover to access the wiring. The bathroom and shower are just on the other side, so I'm not sure how far their linoleum comes under the carpet.
- mikeboExplorerIn the Jayco Melbourne that I used to own there was linoleum under some of the carpet. This was in areas that had tile on one side and carpet on the other. There was tile in the bathroom and carpet in the bed room but part of the bedroom had tile under it, but only part of it. I learned this when I had the area under the bed opened up to work on the transfer switch that was under the bed. It is not safe to assume that all of the carpet has tile under it.
- GrumpyandGrandmExplorer
Motodad77 wrote:
Yes I meant linoleum.... Thanks for the replies, I hope your right Grampa!!
The best way to "be sure" is contact JAYCO...:) - Motodad77ExplorerYes I meant linoleum.... Thanks for the replies, I hope your right Grampa!!
- GrumpyandGrandmExplorerI think he means linoleum. Unless JAYCO changed their production methods the entire floor is covered with linoleum and then the carpet is installed where needed The problem with removing the carpet you will have staple holes where the carpet was attached at the edges.
- Just_JeffExplorerTile is heavy and expensive, and a Greyhawk is an entry-level RV...a high-end entry level, but still entry level, and they don't have a whole lot of CCC to spare. Unless a previous owner did it or ordered it as a special option, that doesn't sound right.
Why would someone carpet over tile instead of just buying a rug? - Jim_ShoeExplorer III can't imagine that a builder would put tile down and then carpet over it. Perhaps the previous owner put the carpet down.
- dbblsExplorerI doubt if it has it. I just toured a Heartland RV factory and their vinyl flooring does not extend under the carpet. Perhaps just a few inches.
38,783 PostsLatest Activity: Sep 24, 2026
