wa8yxm
Aug 10, 2014Explorer III
Not the gas control valve (though that COULD be the issue) I see two possible issues.. one is contaminated fuel (Doubtful but possible).
The other is that it needs a full PM run (preventitive maintenance) INCLUDING cleaning and inspection of the orifice.
This is the brass fitting that extends into the slotted tube (Air door) below the Thermostats... Likely somthing is messing that up.. Also clean the burner's gas tube and anything else you can clean.
38,705 PostsLatest Activity: Jan 26, 2025
