dougrainer
Aug 10, 2014Nomad
The problem is simple and the fix is simple. The burner tube has a small insect web in it. Run and flexible brush thru the burner tube to remove the insect nest. Long shot would be restricted orifice. Just remove and blow out if cleaning the burner tube does not work. Doug
38,706 PostsLatest Activity: Jan 20, 2025
