mtrumpet
Sep 09, 2014Explorer
Thanks all.
Fortunately, in my case, I have have good access to my engine from the bedroom. A section of the floor and the bottom of the closet wall comes completely out as one big L shaped piece along side the bed and it gives me complete access to approximately 2/3 of the engine. The Lift Pump sits only about 8" below the floor level right under the access opening. I can kneel or even lay on my stomach (on a nice soft blanket I might add) and the lift pump is right there.
Mine is the original pump and the problem is indeed the gasket leaking. Cummins told me that the gasket for that old series is no longer available, so the only option is to change out the entire unit. The new unit is an identical match for the old unit with regard to size, mounting and porting. Cummins also gave me all of the plugs, o-rings and seals. They said that I could've used the old plugs, but as long as I was replacing with a brand new unit, might as well go with new hardware as well.
I spent the entire evening last night after work cleaning and degreasing the entire area of the engine and compartment around the location of the lift pump to reduce the chance of debris getting into the fuel system once the fuel lines are remove from the old pump. I plan to take new, clean shop towels and wrap them around the ends of the fuel line with a rubber band to help reduce he chance of getting any debris into them. Then, a big part of the job is moving things (cable harnesses, hoses, heat shield from the exhaust piping, etc.) out of the way to give me as much open working space as possible.
The one thing that is currently giving me a problem...There is a plate mounted to the front of the lift pump assembly, that extends off to one side. In that plate, there is a large cable connection/plug which (supposedly) just unscrews from the connection piece mounted to the plate. I'm have a heck of a time getting that large connector unscrewed! I probably don't have to remove/disconnect it, but by doing so, would allow me to move yet another cable out of the way of the lift pump for easier removal. Will try using a small, rubber strap wrench and see if that will help get it unscrewed.
Just for the heck of it, I grabbed a wrench and tried to loosen the mounting bolts of the lift pump. No luck! They're very tight. (Then again, I didn't want to overdo it either and risk breaking a mounting bolt off in the side if the engine block!). I'll soak'em down with some PB Blaster tonight. Hopefully that will help. (It usually does.)
I have a professional mechanic friend coming over in the morning to give me a hand with getting this project wrapped up. I just hope it goes smoothly. We'll see.
