turbojimmy wrote:
I've seen a lot of good feedback on the TST monitor. I haven't tried it, but it seems to be highly recommended.
I've used the TST system on my last two MH's. I highly recommend the system. The newer flow through sensors allow airing up without removing them.
The system can be setup to handle any number of sensors including your toad. I just ordered another pair of sensors for my newly ordered TAG axle MH.
Not discounting the age factor but I'd bet that the OP's blowout was due to low air pressure not age. Many RVers don't properly monitor tire pressure, especially the inside duals due to access issues.
In addition to the TST system, I also always add the Borg Dually valve stems. They replace, not extend, the valve stems with ones that allow easy airing of both inner and outer tires.
