sunnybrooktoyhaExplorerApr 18, 2015Tire firesWhat's with all the tire fires I've been reading about. Is it due to lack of maintanice or something else. Thanks for your input.
msgtordExplorerApr 18, 2015when you you combine a leaking grease seal with hot brakes, or an under inflated tire, you will get a fire. If you mix all that onto a hot roadway when it's 110 degrees outside, you get a fire in a hurry!
Related ContentBias ply vs. radial tiresSafety: Microwave Fire!trailer tire caused california fireElectrical fireTires- Tires - Tires
