dgtjhatt's avatar
dgtjhatt
Tire inflation
We bought a used Jayco Grayhawk 31ft. Class C E450 frame. The tires were all inflated to 80psi. The door sticker says Rears 80psi cold and the fronts 65psi cold. Wondering what tire pressure all of you with this size unit are running.
Thanks in advance for all your input.
  • Not the same but, but my opinion is to use what is on the sticker. IF you find the ride not to your liking, you can get the mh weighed and adjust pressures to what the tire manufacturer says is required to handle the weight.
