- DAS26milesExplorer III'm waiting until I have to buy a new set of Michellins which only last 3-4 years here in SoCal. (OZONE). Then I will pick up a set of rear dually stems from Borg Tire supply local and have the tire shop install them with the new tires and balance. Only the rears, as all the stems are metal. Labor is only $20 to install the stems. Otherwise, you can pay $75 a tire to install and rebalance.
- BordercollieExplorerOne tire failure can cost you plenty for repair of damage done by flailing steel belt to underside parts of your rig not to mention possible loss of control. Spending $270 for Tire Man set of six valves and installation seems reasonable due to the price of brass. In 2004 we had a truck tire shop make us up and install solid brass valve stems on all six wheels for around $200, call around explain what you want clearly and get estimates.
(Correction $200) - j-dExplorer III did the same thing Gotsmart did. The air-through caps (again with a "pusher" inside) gave me just the right additional reach. Coach now has nine of them. Four rear, two front, one spare and two on Air Bag inflate valves.
NAPA has the caps on their browsing racks. - IAMICHABODExplorer II
gotsmart wrote:
j-d wrote:
Front and Spare can get by nicely on ordinary METAL valves. Just not the very shortest ones if it's Ford wheels. Stem needs to be about 2" to allow gauge/chuck to clear the rim.
On my E450 I added one of these to each front tire to extend the valves past the simulators. I bought them at Les Schwab for $1 USD each.
Those come standard on all 6 valve stems from Tire Man. - gotsmartExplorer
On my E450 I added one of these to each front tire to extend the valves past the simulators. I bought them at Les Schwab for $1 USD each. linky
- VA-ApraisrExplorer III've had mine on my 4x4 camper for 9 years now and I fully air down to 25psi for beach driving at least 8 times a year and NEVER had an issue with these solid metal value stems. I used the extension rubber ones and braided steel ones and BOTH caused leaks and one came loose driving down the highway....not good! So, YES worth the investment to have solid metal values on all tires and especially on the inner dual wheel.
- j-dExplorer II
brirene wrote:
I just finally got some 135 degree steel extenders after looking for a long time. Not an ideal solution, but at least I can check and fill as necessary.
Marginally OK but only IF the valves they're attached to are METAL. The rubber ones barely hold up on their own and the weight of extensions, adapters, etc. really tears them up. Then you have a leak or catastrophic failure where the valve fails and leaves a BIG hole.
The best extenders are "airless." There's a pusher inside. When you put a gauge or air hose on, it presses on the pusher and the pusher opens the valve on the tire. Ordinary extenders press the tire's valve when you tighten them on installation. Then the connection, the extender, and the extender's valve can all leak.
Back to the OP's question: YES!!! Very much worth having custom valves, whether bought or made up. We really need only a rear set. Front and Spare can get by nicely on ordinary METAL valves. Just not the very shortest ones if it's Ford wheels. Stem needs to be about 2" to allow gauge/chuck to clear the rim. - brireneExplorerI just finally got some 135 degree steel extenders after looking for a long time. Not an ideal solution, but at least I can check and fill as necessary. About 14 bucks from the rv dealer.
- IAMICHABODExplorer III don't really know what you mean by performance,but I have had mine for 5 years and 2 sets of tires and have had no problem at all with them. The flow thru caps make it easy and fast to check and add air if needed.
Here is a friend that had them for 9 years back in 2013 thru 4 sets of tires and they are still going strong with no problems.
Yes I think they are worth the cost,but that is just me,I have no problem buying and using a quality product that will give you long life and make things easier. - MobileBassetExplorerHave you checked with your local commercial truck tire business, where the 18 wheelers get their tire work done? They can make you the same brass extenders and install them for a much lower price. At least they do where I live.
38,761 PostsLatest Activity: Nov 16, 2025
