- IAMICHABODExplorer II
leeper wrote:
That is a photo of a wheel simulator with Tire Man Valve Stems and not mounted on a wheel. They really do not fit that well on an actual wheel.
If you will look closely you will see that it is indeed mounted on a wheel. - WA7NDDExplorerI have had the Tire Man extenders on our class c since 2014 and they work fine. I took a 2500 mile trip no problem. Just installed the TireMinder TM66 on the extenders because of the good price Camping World had on the TM66. It was nice to screw the transmitters onto the extenders and they did not even wiggle a bit.
- leeperExplorer
IAMICHABOD wrote:
leeper wrote:
That photo is of a larger oval hole. Mine are round and 8 of them.
Oh in that case here is a picture of your wheel with the Tire Man Valve Stems
That is a photo of a wheel simulator with Tire Man Valve Stems and not mounted on a wheel. They really do not fit that well on an actual wheel. - BobboExplorer IIII dremelled my notches. Easy Peasy.
- j-dExplorer III had to notch just a little. Eight-Round-Hole Simulators, BORG Dually Valves. Easy enough. But I'd suggest you cut or grind your notches. I did that on one side after I thought I could dimple the stainless steel a little to gain the clearance and it cracked. I'd rather have a ground-out spot (Dremel Tool) than a crack. Still, the tiny crack has not spread.
chinrv wrote:
How were the wheels balanced by the tire installers with the long tire stems in the rims? Did they present any problems?
Mine balanced out just fine,no problems at all,they aren't that heavy.
Much lighter than the extenders that some use. - IAMICHABODExplorer II
Oh in that case here is a picture of your wheel with the Tire Man Valve Stems - chinrvExplorerHow were the wheels balanced by the tire installers with the long tire stems in the rims? Did they present any problems?
- leeperExplorer
Bobbo wrote:
While I did have to notch a couple of the wheel simulators, it is not noticeable at all.
Thanks Bobbo for the info. I am going out to make the notches now. - leeperExplorer
IAMICHABOD wrote:
leeper wrote:
Something that is not discussed about these long tire stems is that the chrome simulated wheel covers will not fit unless they are modified by notching the wheel cover hole larger in order to clear the new stems, or leave the covers off. Both ways do not look good when done. All the Ad photos show wheels without the simulated wheel covers.
That is odd here is a picture of Tire Man valve stems on a Ford Wheel with simulators and I see no cut out,they fit perfectly in the center of the hole.
38,749 PostsLatest Activity: Sep 11, 2025
