cameronpatentla's avatar
Aug 09, 2015
Tire not holding pressure
Our new 2016 Winnebago ERA 70X has Continental Vanco 4Seasons tires. The front tires are supposed to be at 60 psi. The left front has had no problem maintaining that pressure, but since we bought the unit last month from McClain's RV in Denton, Texas, the right hand front tire has had to be re-inflated a couple of times to get it from about 40 psi back to 60 psi. Just now, after a 300 mile trip over the weekend, where both fronts started at 60 psi cold, now the left front is still at 60 psi cold, but the right front is back down to 40 psi. Other than the obvious answer that the tire is not holding its pressure, any ideas on what could be causing this (e.g., warped rim, etc.) Has anyone else experienced this with a new MH? Thanks, Mike
  • newman fulltimer wrote:
    cameronpatentlaw wrote:
    Just got back from NTB and Goodyear. Neither one had a lift that could raise 11,3000 pounds. Both of them said to take it to an RV dealer. The guy at Goodyear suggested running Windex around the rim to see if there is a broken seal between tire and rim (did, looks fine). He also said chrome rims are notorious for developing miniscule cracks. Heads up, McClain's RV.
    tire shop does not have a jack:h
    :S :S
    Not just any RV dealer but the one you bought it from.
    Brand new vehicle: USE the warranty that it came with.
  • Just got back from NTB and Goodyear. Neither one had a lift that could raise 11,3000 pounds. Both of them said to take it to an RV dealer. The guy at Goodyear suggested running Windex around the rim to see if there is a broken seal between tire and rim (did, looks fine). He also said chrome rims are notorious for developing miniscule cracks. Heads up, McClain's RV.
  • If this was on your car what would you do :H
    GO to a tire shop and get it fixed.
    Discount Tires fixed a leaker on my truck for FREE and I hadn't been a prior customer........am now!
  • Thanks for all the quick, and helpful responses. I'm off to NTW now! These forums have the best audience. Cheers, Mike
  • Go to a good tire store and have them remove the tire and check for slow leak, probably a nail hole like pointed out above. If so, the repair is relatively simple and inexpensive; definitely get it taken care of real soon!
  • Nail, screw or something in the tire. Valve stem bad, loose valve core. As a last option a cracked wheel. You really need to take it to a qualified tire store and have them do a leak test. Could be simple, then again it could be serious.
  • I experienced this with my car and they found a nail in it. Could be something like that. The tire company plugged it up (for free) and off I went again.
