If I can't lower, then I may start down the rabbit hole of practical solutions to soften the feedback. Like I said, most of the time it's fine, but bad roads and potholes are rough. I have looked at airbags, spring compression, shocks etc. Not sure which the most practical solution would be with the best results. And I am not going to spend absurd amounts either. I mean there are only so much you can throw at it before it's more practical to trade up.
That said I have read a LOT of posts on here about folks have backed off PSI from max to settle things down a bit. Hence why I asked. Max is Max under Max condtitions. I just need to see where I am with respect to max conditions.
I want to be safe, rest assured. I carry precious cargo. Still at 83 psi, but man it can be rough at times.
