georgelesley
Nov 09, 2017Explorer II
Tire pressure....again
OK guys, I am thoroughly confused. Our right front tire has recently, in the past several hundred miles, started wearing on the outside. First thought was alignment, but the wear pattern is not typical of toe in toe out wear. This is about a 1/2” well defined wear groove from the edge towards the center of the tire. It isf maybe 1/8” deep then normal tire. In my experience alignment manifests itself with a even, tapering wear pattern
I did not feel any cupping,or other wear on any tire, including the one in question. Next week I am taking it to a truck tire shop for alignment check and repair if needed. The alignment guy asked what pressure I was running. I told him 90 , which is what WGO prints on the placard inside.
He suggested 120 would be much better. I just chatted with someone on the Michelin website, gave them the corner weights, tire size (22.5 235/80 Michelin XRV), and they recommended 70!
OK so whom do I believe, a professional tire guy who says 120, or WGO which says 90, or the tire manufacturer who says 70?
Hint: since the problem is new, and all other tires are OK and the tpms shows similar temps and pressures on all when running, I am inclined to stay with 90. Monday when the mechanic looks at it I will not be surprised if he finds a mechanical issue.
What am I missing here?
