Vulcan_Rider
Apr 19, 2015Explorer
tropical36 wrote:
As said over and over again, at least weigh each axle and use the tire inflation chart for your size.
And as I have said before (not often 'cause I'm new here) all of that should ***NOT*** be necessary if everything is still stock.....or better in the case of tire ratings.
In that case, you should be perfectly fine with the original recommendations. Finding out what that is should be much easier that finding a truck scale.
If you are OCD or a little paranoid, then by all means get each axle weighed and check the charts. Any place with scales for semi trailers should be able to do it.
Your point about "upgrading" the tires without considering the wheels too is an excellent one. You actually could be doing more harm than good.
38,774 PostsLatest Activity: Apr 26, 2026
