T-Dawg's avatar
T-Dawg
Tire Pressure Quandry
I have a 2003 Fleetwood 24' Class C RV. I purchased it used with almost new tires on it. The Ford cab door jam sticker indicates LT225/75R 16E tires (front and rear) with Front @ 65PSI and Rear @ 80PSI.
The Fleetwood sticker inside the closet door in the RV indicates LT225/75R 16E tires (front and rear) with Front @ 65PSI and Rear @ 60 PSI. Normally, I would go with this recommendation, BUT...
I just realized (after a year!) that the tires on the RV the previous owner put on are actually LT215/85R 16E! I don't know how much difference this would make in the amount of PSI I should use in these tires, but would appreciate any input forum members would care to offer. Thank you for your help.
  • Your 215/85R16 Load Range E tires take, and require, the same pressures as 225/75R16 Load Range E tires.
    I stopped using what my 24 foot Class C came stock with when new - 225/75R16 Load Range E tires - two tire replacements ago. 215/85R16 Load Rand E tires are about 1.1-1.2 inches larger diameter (but they are slightly narrower width) than are the stock 225/75R16 Load Range E tires.
    I prefer the taller tire for more ground clearance. Also, my Class C's chassis is an E450, which has slightly lower rear differential gearing than an E350 chassis. The taller tires offset some of this lower rear differential gearing so that E450 fuel mileage is improved a bit up towards fuel mileage of an E350 chassis.
  • You should be able to find a tire pressure chart for the brand tires in use on the Internet. Using the axle weights which should be on the Fleetwood sticker you should be able to locate the correct tire pressure.
