becker wrote:
This question has probably been asked before but upon searching I couldn't find anything.
When traveling from a northern state where the temperature is well below freezing to an southern state where the temperature is 70 degrees, how do you handle your tire pressure settings?...... and if the situation is reversed. When in a warm area and your tire pressure is set correctly (in the morning before getting on the road) and the next morning (in the cold area) your tires are showing 10 degrees or so low, do you take your tire pressures back to the correct settings before getting back on the road? Tire size is 295/80R/22.5 Michelins with about 2000 miles on them.
Where can I find some information of this subject?
Thanks.
As I've stated many times and just recently on another thread, weigh each axle and then provide a cushion of 15psi over what it says on the inflation chart for all the variables.
