j-d
Apr 26, 2016Explorer II
samven1 wrote:
I put the TST system on my RV and did not notice any difference. I would not expect any in the rear because the valves on each wheel are 180 deg from each other so they should cancel out, but was worried about the fronts but I cant feel any vibration.
I didn't add TPMS, but this is the same way I see the even heavier Custom Valve Stems. At 180* apart, I never felt the rears would be an issue. That said, I didn't replace the front Valves with Custom, but for the front, the slightly longer Brass stem doesn't weigh noticeably more than the standard chrome-over-steel-or-brass one.
But - Please don't add any significant weight (like extenders) to RUBBER valve stems on your RV. The weight and vibration will cause any non-metal stem to worry into failure right at the rim.
38,763 PostsLatest Activity: Dec 05, 2025
