sew0177's avatar
sew0177
tire pressure
I am preparing to install the eez tpms and went online to the michelin inflation tables. My tires are 275/r80 22.5 load range h with a front axle weight of 10840 and rear axle weight of 18340. This makes the front corners at 5420 and rear corners at 9170. According to michelin the front tires should be at 80psi and the rear at 90. I was a bit suprised by this as most of the posts I read here always had 90 to 100 psi. Does this sound right?
  • Remember, the chart gives the MINIMUM PSI for a given weight.
    If these are not individual wheel position weights, add 5 PSI to account for side to side imbalance.
    I always add a 5 PSI "safety reserve" to the minimum.
    So, 5-10 PSI over the minimum.
  • My inflation rates per Newmar table are 100 psi each 255/80/22.5 tire, front and rear. Check in the driver's area for manufacturer chart listing inflation rates.
