Cstoliker's avatar
Cstoliker
Tire pressure
I just had new tires put on my class C. The new tires seam to have a bit more flex on the sidewalls then the old ones. The tires say max pressure 80psi for load range E. But the sticker in side the drivers door says 65psi front and 80 rear. I lowered the pressure to 65 on the two front and they look soft to me. Pictures are below. Should I just run them at 80 to? All tires are same size LT225/75/r16 load rang E (wich is what the sticker in the door recommends.
