Googled your tires and in the same sise I even found J-load from wich I dont know wich yyy belongs to that, but on goodyear site found 125psi and maximum load single of 6940 dual 6395 wich is loadindex 148/145.
with yyy ( wich is called the reference pressure Pr and is not the maximum pressure). Filled this in with the loads you gave and assumed behind to be dual , because otherwise 2 tires cant carry the axle load.
Here the picture , beneath the presssure advices of 93/96psi with 5% loadreserve, wich is not exagerated , aditional information about weightdivision and used percentage of the tire maximum load etc.
So the 100 psi all around is ok and I played with the reserve to find 12% reserve front and 9 % reserve rear at 100psi wich is still ok and wont give bumping still , concluded that to happen under 85% L% given in the spreadsheet wich is the same as adding 18% , but discussable I know.
The pdf and Excel xls file is also in the examples map on my skydrive that belongs to my hotmail adress.
examples map in the map of the calculatorSo if you find the GAWR's you can add them and you get more aditional information about the axles. If the tires apear to be different you can chanche that too in the spreadsheet.
