HighwayJunky
Sep 20, 2017Explorer
Tire pressures and my air compressor
Ok, so granted I am not the heaviest brick in the load so thought I'd ask this question. It might be simple logic but I want to be sure. My RV tires are to be at 130PSI front and 120PSI rear.
My air compressor states that it has a maximum pressure or 150PSI tank pressure. So,if this is running properly it should fill the tires to their respective pressures. Right? Should I assume that since the tire pressure is to be 130 and the max pressure from the compressor is 150 then the amount added is only 20PSI and it a very slow rate??
Or should I get a higher PSI capacity air compressor to do the job?
