When traveling with your RV your maximum tire pressures are 110 when it reaches 110 is the general rule of thumb to stop and lower the pressure back to the starting point of 90 to 95 psi? I just bough...
Maybe I just need to reword what I’m saying I’m saying on a long trip I’ve got a tire pressure monitoring system and when I see the pressure getting up to 110 psi do you guys continue letting it to rise or do you readjust it back down to the starting point and continue on with your trip. I was just concerned that reaching 110 psi which is the maximum PSI when you’re driving and it gets above 110 is that a good thing or a bad thing.
