jswat wrote:
Thanks everyone for your input. The strange thing is, it worked fine until about one month ago, and has for several months on this same setup. I do have a six-pin connector on my MH, I may just have to re-wire it and see if it works that way. Sure hate crawling under the beast and working on my back. Also, I do have the magnetic lights which also work just fine connected the same way. I'll be sure to re-post when (or if) I find a solution.
The way I read this is the only difference between the magnetic lights and the toad lights are the diodes. Mine are the same. The low voltage from my motorhome will work for the magnetics but the diodes will not allow it to pass.
