TNGW1500SE's avatar
TNGW1500SE
Toad overweight?
I have a 2003 Itasca Sunova 30B. I'd love to tow a van with 2 motorcycles in it. The bikes weight about 800 for both of them. I'm looking at vans. The little ford transit connect weights somewhere in the 3500 range empty but it's small and would be hard to get the bikes in. Ford makes a bigger van. The Transit. The stripped cargo version weighs about 5000 without fuel. That would put me at about 5800 if I kept it as light as I could. I think my Sunova is rated at 5000 so I'd be a "little" over the rating. I think I could tow it ok and if in the mountains we could always unhook and the wife could just drive the van. I know I'm going to get blasted by everyone but I thought I'd listen. I'll weight the motorhome but we've stripped some weight out of it and would lighten the load as much as possible in the RV. Thoughts???? Thanks in advance. All advice read even if not followed ;)
  • I met a member who tow Subarban with his 30-something DP with no problems.
    In California we do have long, steep grades whenever we turn.
    The extra weight will just make you going slower, but that is going to be good test for coach transmission and cooling system. (assuming you do have good toad brake)
    Make sure they are well maintained.
    Getting at 3 AM to make grades before day heat can suck on long run
