klutchdust
Sep 19, 2014Explorer II
map40 wrote:
Yeap, it is not easy, but it is what you need to do. It MUST be in neutral, and my 2 jeeps called for the tranny in Park. Any other combination will fry the transfer, the tranny or both.
Don't worry, it will loosen up with use.
Found a more detailed explanation on Quadratech's website. My 08 is easy to transfer from one range to another but not without the engine running. Going into neutral is fine coming out
is a different story. Their method says, once you reach your destination Shift the automatic into neutral, it was in park, shift the transfer case into desired position then shift the transmission
into drive. Then they say Note: It may be easier to shift the transfer case if you start the engine first.
The owners manual doesn't say that. The OM just warns about towing on a dolly, front wheels up.
38,766 PostsLatest Activity: Jan 10, 2026
