Dale_Traveling
Aug 19, 2015Explorer II
Not sure what is meant by in sync. Left turn on the coach but right turn on the CRV? Is the CRV configured with extra lights that are only used for towing or is the vehicle configured with diodes? What has changed since the last time the lights were verified?
If the CRV is wired up to use diodes rather than retrofitting extra towing lights the configuration can be tricky and require an extra item to make it work correctly which could be the source of the problem. Since I went the diode route I also had to use one of THSES with my CRV to get everything to work correctly.
Related Content
- Feb 01, 2026Community Alumni
