Blaster_Man
Aug 19, 2015Explorer
BTPO1 wrote:phillyg wrote:
Look also for a bad ground. Using a voltmeter can occasionally be difficult. I've found using a single wire with alligator clips at each end can be used as a test jumper to bypass components, providing a ground alternate. Just used one today to jump a bad tail light ground to my trailer, tail light lit right up telling me the ground wire needed to be cleaned and reattached more securely.
I also like to use jumpers, but I use fused jumpers to prevent any problems with wiring. It's as simple as putting an inline fuse on one end before the alligator clip. JMO
Good suggestion...check the ground.
Related Content
- Feb 01, 2026Community Alumni
