Berner2 wrote:
I am in the process of reflooring and I'm gonna replace my toilet while I'm at it. I have never had an RV toilet off before.
I have my old toilet off and the flange unbolted from the floor. It appears the flange is attached to a piece of abs that extends into the black tank and is sealed at the top of the tank so that it will slide in and out and also turn. Is this correct?
I will be raising the flange a little and I want to make sure it's made to compensate before I go yanking on it. I am also going from a four bolt toilet to I believe a two bolt. My flange seems to have enough slots to accommodate either style toilet. Is this correct?
From my massive pool of knowledge (A whopping 2 flange replacements), I have found that the down pipe is screwed and glued or just plain glued into the black tank. The flange is screwed and glued as well. If you are lucky enough to have a straight pipe into the black tank, you can often break the thread free and unscrew it up a bit to compensate for new flooring. As I read it, I'm not sure I am making any kind of sense...
