Old-Biscuit
Feb 22, 2014Explorer III
The blade sits on an actuating assembly that is operated by a cable from a front pedal or by direct linkage on a hand lever.
The bowl separates from base via screws under top lip of base.
To repair you will need several replacement parts
Bowl to base seal
Bowl/blade seal
Foot pedal cable/maybe foot pedal depends on where it has broken
OR hand lever assembly
Possible new actuating assembly
Blade seal
Blade if bad
Blade track
Throw in a new water valve and vacuum breaker
Here is a link to installation & owners manual.....CLICKY
SO might as well replace that old 1994 model with a new toilet.
Conversion Chart......LINK
Bowl to base seal
Bowl/blade seal
Blade seal
Blade if bad
Blade track
38,768 PostsLatest Activity: Jan 26, 2021
