kioticoachman
Jun 03, 2018Explorer
ncscz wrote:Yes ... Water is running into the toilet bowl after its been flushed and keep on running. The only way I could think of to stop it was to shut off the DC to the RV. That worked ... but it also shuts down the Refrige as the DC, I believe activates the Control Panel AC to the unit. Maybe I should try to locate and remove the fuse for the water pump for now and than see if I figure out How to get to the flush valve on the toilet bowl, etc. Thanks for the suggestion I believe that is the cause of the problem.
Does the water fill the bowl and overflow? If the sliding blade in the bottom of the toilet does not seat completely back into the groove the water can continue to flow. If SOMETHING is keeping the blade from sealing, that can cause this problem.
Will look into this further. There are two (2) hand levers. Gray & white (flush & rinse). Usually use flush lever. When flushed let it close and that shuts off the H20. Now It just keeps on running.
