kioticoachman's avatar
Jun 03, 2018
Toilet Keeps Running In My RV ??
Have an older 2001 Ford Coachman Class C Motorhome Catalina Sportsman. After flush activation Toilet (pump) decided to keep running. Any an all suggestions would be very much appreciated. Shut off the 12 DC and that stopped pump from running. WOULD like to know what/how is involved to track down and repair the problem! Hope this helps? Any an all suggestions would be very much appreciated. Thank you for taking the time to assist this SC with this matter.:? KC 62-66 USAF
  • Jim@HiTek wrote:
    Most of those RV water pumps have the fuse for the pump just a few inches from the pump itself. Usually within 6 inches. Find the pump, and the fuse will be there.
    That was my biggest accomplishment so far. I located the DC Fuses and believe it or not it was labeled properly for the pump so pump is now inoperative. All other apparatuses are working satisfactorily.
  • j-d wrote:
    Most likely the "flush valve", "water valve" or whatever the parts list calls it. Or a problem with the linkage from the Hand or Foot Control that activates said valve. Possibly some foreign object is keeping the valve or linkage from closing.
    Post Brand and Model of Toilet and we can try to find a parts list. Parts aren't cheap, so new toilet may be in order. When you repair or replace it, you'll need a new Seal Ring (prevents leaks between Toilet and Floor Flange, and it's Foam Rubber not Beeswax like we have at home), AND!!! Install a shutoff valve in the line supplying the Toilet. Then you can still use the rest of the RV's water system.
    Brand is Thetford Model AM IV LD .. Hand Flush.
    Part # 20919 602
    Code 000928
    Appreciate the suggestions. They are well taken. Hopefully I will be able to make better progress in the AM.
  • j-d's avatar
    j-d
    Explorer II
    We have an AM IV hand flush, cheapest thing Thetford makes. Still, it works just fine.
    AM IV Parts
    13168 Valve Kit $27 Amazon
    AM IV Parts
    The Valve Kit and # you provided will be the first purchase I will make. Will try to keep you all posted on overall progress. Still contemplating on whether to completely remove toilet or try to replace the parts from the backside. Probably best to remove the unit and check & clean the mechanism and replace parts and may include some of the other modifications that have been mentioned at this time. Thanks for searching out the kit and providing the info. KC
  • j-d's avatar
    j-d
    Explorer II
    I haven't had to take our AM IV apart. Look at the exploded parts diagram. I think you'll find you have to take it off to have the access to get it apart. You may find it a little tricky. Heard the AM V was brought out to simplify the design.
    Thetford recommends plugging the vent that you see in the bowl rim below where the water comes out. They now say it isn't needed, and can let tank odors into the RV.
