The bowl has come loose from the base of the toilet in my motorhome. The bowl is porcelain and the base (with the flush valve) is plastic. Looks like I will have to remove the toilet and turn it over ...
Found the manufacturer name and model number. Called the manufacturer and they said yes the bowl can be tightened to the base with the two bolts on the back side of the toilet. They told me if I don't have enough room between the wall and the toilet that it would have to be removed to tighten the bolts. The seal can be reused but they recommend a new one.. Thanks for everyones help.... Roy :)
