J-Rooster
Aug 31, 2016Explorer
Toilet Seal
I have a question for all of you who had minor toilet seal problems. My toilet seal is leaking water at a very slow rate. Even though it won't hold freshwater inside the bowl there is absolutely no fo...
louiskathy wrote:I don't use very many chemicals in my black tank because we empty it very often. But when camping in extreme heat we use a chemical (for smell) that does not have formaldehyde in it. I use WD-40 to lubricate my pull handles. After, I pull the handle out, I squirt the rods twice then push the rods back in. I'm on Chimo so I try and stay away from chemicals as much as possible, my oncologist doesn't want me to handle or smell chemicals.
What are you using in the black tank to lubricate your pull handle valves?
(and please... no comments from the "you don't need chemicals in the black tank" group.)
Do you just pour that down the toilet ?? Let it sit in the toilet bowl a few hours and then flush it down into the tank.
Anything that says it's a black tank product that lubricates valves... is gonna work. I use odorlos from Camping World Catalog Item # 58996 . Amazon has it too.
