J-Rooster
Aug 31, 2016Explorer
Toilet Seal
I have a question for all of you who had minor toilet seal problems. My toilet seal is leaking water at a very slow rate. Even though it won't hold freshwater inside the bowl there is absolutely no fo...
usersmanual wrote:Interesting post?Matt_Colie wrote:
Rooster,
As an Ex-engineer with Thetford, I will tell you that there is a good possibility that the seal system has been fouled by calcium papitate. Just a little CLR (easier to get than most acids) and that may do it by itself.
Matt
mine will leak and its not any calcium. I use vasoline as a lube and when sitting all summer I use cooking oil.Just pour a little around the seal and fill bowel with water. holds all summer long
