dougrainer
Feb 04, 2017Nomad
1. Some toilets you do have to pull to tighten the Seat bolts
2. Usually, if you lift up the seat to put pressure on the underside nut, you can then turn the slot/phillips screw tighter.
3. There is one toilet (not sure of the model) where you have to tighten on the bottom side nut, they have no screwdriver type screw on top.
4. WHY would you go to the Factory for this type problem???? Go to a RV Service center. Doug
